    Dismiss Notice
Shock Oil?
Discussion in 'Shop - Suspension & Steering' started by RRacing, Apr 12, 2012.
  1. RRacing
    RRacing Well-Known Member
    Jun 7, 2005
    Mesa, AZ
    I wanted to get some opinions on what shock oil you all are using. I'm running Bilsteins 2.5" triple bypass on my Jeepspeed, and was told by Bilstein to run 5 to 7 weight shock or hydraulic oil with a minimum temp of 300 degrees. Looked online and saw mostly Fork oil when I searched for it. I have seen a lot of people say that synthetic ATF will work just as well. What do you think? Please include specific brand info. Thanks.
  2. BRINGTHERUCKUS
    BRINGTHERUCKUS Nimrod de PMC
    Apr 28, 2005
    Parker/Tucson, Arizona
    ATF will "work" but you dont want to use it... Give Kris Hernandez a call at Shock Seals (actually i cant find his number so go to shockseals.com and it has all the info youll need if not email him) he'll get you pointed the right way, . FOA makes some cheaper shock oil but i dont think youd want it in a bilstein.
  3. baja619
    baja619 Well-Known Member
    Aug 7, 2004
    Corona / San Diego
    Lucas Oil is hearing great reports from the field with their shock oils. Desert Racers, Short course to industrial. They have 2.5wt all the way up to 20wt; All purpose formulated Shock Oils.
  4. Ramsey_ElWardani
    Ramsey_ElWardani Ironman
    Apr 1, 2001
    I have 4 gals of Bilstein oil that you can have in El Cajon, CA.
  5. RRacing
    Jun 7, 2005
    Mesa, AZ
    Sounds good. Can you cover the shipping to AZ.;) What would it cost to ship to Mesa, AZ?
  6. Ramsey_ElWardani
    Apr 1, 2001
    I wouldn't want to hassle with shipping - someone is always driving back and forth from SD to Phoenix.
  7. philofab
    philofab Powered by Optima
    Jun 13, 2006
    JRod's livingroom.
    I buy Ultra Extreme or Extreme shock oil from F&L / Amber Racing Services.
  8. RRacing
    Jun 7, 2005
    Mesa, AZ
    Does anybody know if there is a F&L distributor here is the phoenix area?
  9. philofab
    Jun 13, 2006
    JRod's livingroom.
    In Phoenix you could get shock oil from SDHQ.
  10. kdm73091
    kdm73091 Well-Known Member
    Aug 27, 2008
    west hills
    Dte 11m oil is the sht ive heard.
  11. cosmo
    cosmo Super Moderator
    Apr 1, 2003
    Encinitas
    Thru F&L you can order a 5 gallon can also.
  12. Ol' Curmudgeon
    Ol' Curmudgeon RDC's resident crackpot
    Dec 29, 2004
    The Cloud
  13. Kritter
    Kritter Krittro Campbell
    Jun 18, 2001
    Pick the weight of oil you want then get the one with the highest viscosity index you can afford.
    Maxima makes great oil used in some of the fastest TT's out there
    F&L makes Fox oil
    King uses Shell oil
    SAW uses semi syn Torco oil
    A podium jeepspeed with 2.5" shocks will run 300-350F assuming its not overweight. Overweight you can be pushing 400F.
    Dont use ATF. Yes it works, not if you want to be competitive in that class. Next to prep, shocks are everything in that class. Rebuild them every race with fresh seals and oil. Ive worked with the fastest jeepspeeds out there and know what it takes to win.
    Shoot me an email [email protected] if you want more specifics. If you talk to Bilstein Joel, he will point you to me for seal kits if he cant take care of you right away.
  14. PNW078
    PNW078 Member
    Dec 15, 2006
    Silverton, OR
    Use oil designed for shocks, not fork oil. Shock oil is designed for higher heats in an airless environment. Forks operate at lower temperatures with air present and have anti foaming additives. You can cook fork oil in shocks. Maxima does make an excellent shock oil in 3, 7 and 10wt. Most motorcycle shops stock it and can order pails. Other motorcycle brands also offer good shock oils, I think Bel Ray goes up to 20wt. Also look for Spectro, Torco, also excellent products.
  15. Sparky
    Sparky Well-Known Member
    Apr 4, 2006
    Feeniks, Aridzona
    Our Bilstein's don't get anywhere near that hot. And we podium. They used to get that hot until Joel worked his magic on them. We use whatever oil Bilstein puts in them.
  16. Kritter
    Jun 18, 2001
    How are you verifying temp?
    Magic doesnt defy physics.
    Helgeson, Hartman, Coan Wrangler, Wacker, Coan Cherokee(3" shocks) , Griffith, Lafortune(3" shocks), etc...run/ran those temps.
  17. Sparky
    Apr 4, 2006
    Feeniks, Aridzona
    I don't think any of them ran Bilsteins. The discussion is regarding oil for Bilstein, not Kings. We run Bilstein and I know what temps they run. Just because ^^^their shocks got that hot does not mean that *all* shocks get that hot.
    Temp indicators and with a gun.
  18. cosmo
    Apr 1, 2003
    Encinitas
    What oil are you using?
  19. Sparky
    Apr 4, 2006
    Feeniks, Aridzona
    Some spooky voodoo magic stuff. Honestly I don't know exactly what it is.
  20. philofab
    Jun 13, 2006
    JRod's livingroom.
    Bilstein uses F&L Ultra Extreme shock oil.
Verification:
Draft saved Draft deleted
Share This Page
