    Dismiss Notice
Spindle question
Discussion in 'Shop - Fabrication' started by dirt_bandit, Sep 21, 2005.
  1. dirt_bandit
    dirt_bandit Member
    Jan 16, 2004
    chula vista, CA
    i dont think a stock cast spindle should really even be welded on? but someone can correct me if i am wrong
  2. Philip
    Philip Member
    Sep 15, 2005
    encinitas, ca
    I have asked the same thing and been told different answers. I would personally never do it and would never reccomand someone else to do it. You really have to know what your doing.
  3. Byrdman
    Byrdman Asked to be removed
    Mar 10, 2003
    Burbank,Ca.
    After welding to a stock cast spindle, like a gusset or other fabrication work, is it recommended to re-heat treat or just normalize the unit. I'm wondering because the spindle body is cast, and the plate or gusset is cold rolled steel- two different materials. I've heard a few different ideas, just need some imput before I send the units to a metalurgist.
  4. mosebilt
    mosebilt Well-Known Member
    Jan 31, 2005
    upland,ca.
    forged spindles are ok to weld on (just pre-heat them),cast is no-bueno.
  5. Byrdman
    Mar 10, 2003
    Burbank,Ca.
    How can you tell if they are cast or forged? They are early Ranger spindles, once heated up properly, they welded very nicely.
  6. MH20
    MH20 Well-Known Member
    Jan 19, 2002
    San Diego/Orange County
    Rangers are all cast. What type of welding did you do to them?
  7. Byrdman
    Mar 10, 2003
    Burbank,Ca.
    MIG- I've seen some gusset work done to the stock spindle, especially re-enforcing the steering arm and plate work to use after-market calipers and if done properly, works just fine.
  8. ntsqd
    ntsqd Well-Known Member
    Sep 17, 2001
    Here
    I'll guess that cast iron vs. cast steel is being confused. Iron doesn't weld very well and would be pointless to try to gusset. I'd be very surprised to learn that a spindle was made from cast iron.
    Cast Steel, on the other hand, should be weldable if the normal techniques used with thick sections and/or highly stressed parts are followed.
  9. MH20
    Jan 19, 2002
    I actually have a set of Baker spindles on my truck with exactly that setup on them and have yet to have a problem with them.
  10. Byrdman
    Mar 10, 2003
    Burbank,Ca.
    Thank you very much!!
Verification:
Draft saved Draft deleted
Share This Page
