    Dismiss Notice
what drums are you using???????
Discussion in 'Class 9' started by mdepue, Sep 24, 2010.
  1. mdepue
    mdepue Well-Known Member
    Jul 29, 2009
    barstow
    well i just cracked a thing drum putting studs in :mad: so what is everyone using and the ones using thing drums is there a secret for putting studs in???
  2. oldman dirt
    oldman dirt Well-Known Member
    May 2, 2008
    some where in the desert
    done that I tig welded it up and am using it-------seems to be a common thing------
  3. mdepue
    Jul 29, 2009
    barstow
    well we did type 3 derums and they were easy but then decided to run thing trums and it wasnt so easy
  4. 9Iron
    9Iron Well-Known Member
    May 15, 2006
    Franklin, CA
    Have had good luck with the type 3 drums.
    They will bend first, where the thing's will just crack.
  5. mdepue
    Jul 29, 2009
    barstow
    So What should I do get another thong and run those if I can finally get it or run type 3
  6. M.Harvey1600
    M.Harvey1600 Well-Known Member
    Mar 5, 2007
    Riverside, Ca and Cal Poly Pomona
    THONG??? haha I think I know what is on your mind... I always heard that Thing drums are the way to go. If I were you I would contact Doug Silcock (Doug969)... He knows his stuff on 9 cars and everything else for that matter
    Doug969:http://www.race-dezert.com/forum/member.php/1295-doug969
  7. mdepue
    Jul 29, 2009
    barstow
    hehe well you got me! lol okay back to racecar now!!
  8. doug969
    doug969 Well-Known Member
    Dec 7, 2003
    Glendora CA
    Type 3 are going to be your best shot IMO. Thing drums are good because they are wider and you can use type 1 standard backing plates that are easy to get compared to the type 3's. The thing drums are a little soft from what I have seen but do work you have to make sure you use the right drill bit and be drilled correctly with a small countersink. What has worked for me is a deep socket or a tube that is long enough that is wont bottom when you press the stud all the way in and that has a ID just a tad bigger then the stud so you wont jack the threads when pressing but must be center. The reason I do that is because if it has to much room around it when you press it in it will crack and wont to push through the drum. It should be a tube or socket that has some width so it wont bend and have a large enough surface to support the pressure and spread the load while pressing it in. Hope this helps
    (+1) 1 person likes this.
  9. mdepue
    Jul 29, 2009
    barstow
    We'll I think were gonna run type 3. Any ideas on where to get backing plates for them?
  10. doug969
    Dec 7, 2003
    Glendora CA
    try John at RC trans in Vegas. Or maybe the VW scrap yard in hesperia Small Car Conection
  11. mdepue
    Jul 29, 2009
    barstow
    Alrighty will do thanks
  12. Faulk9
    Faulk9 Well-Known Member
    Dec 11, 2009
    Las Cruces, New Mexico
    John is cool as shizzle. Call him @ 702.221.4363.
  13. Faulk9
    Dec 11, 2009
    I could not resist.........................................What kind of drums are you using?....................Ludwig
  14. mdepue
    Jul 29, 2009
    barstow
    what do you mean?
  15. Faulk9
    Dec 11, 2009
    Just trying to be funny...haha
  16. mdepue
    Jul 29, 2009
    barstow
    Oh yes jajaja
  17. Faulk9
    Dec 11, 2009
    Another good guy that knows alot is Joel Mohr........760-947-6647. He has helped me alot and answered alot of my questions.
Verification:
Draft saved Draft deleted
Share This Page
