    Dismiss Notice
XR650L Carb Problems (need advice)
Discussion in 'Bikes' started by Boston Mangler, Nov 8, 2006.
  1. Boston Mangler
    Boston Mangler Well-Known Member
    Jun 11, 2005
    San Diego
    Hey Guys
    I got a 2006 XR650L that i just desmogged, uni-air filtered, and installed a carb with the mods listed below.
    I have the carb setup at: 55/158 jets, mix screw 2 1/4 out, needle shimmed .010. Most other folks say that this is the perfect setup for the L at sea level.
    My bike is running rich still and seems to be getting way too much fuel. After a good hard ride, i will get some fuel seepage from the carb vent as well.
    One of the guys on the 600/650 section mentioned that i might have "bumped" the floats and thats causing it to flood which would explain how its running. Anyone have any experience with this care to elaborate on how i can tell if i bumped my floats and if so, how to fix em?
    My friend that i ride with also says i am puffing a little smoke on Decel
    Any advice would be great!
    Thanks [​IMG]
  2. Chase 2
    Chase 2 Well-Known Member
    Jan 8, 2005
    Simi Valley, CA
    puffing smoke on deceleration can be an indication of valve guides, which wouldn't help jetting woes.
  3. Moss2
    Moss2 Well-Known Member
    Mar 24, 2006
    Lincoln, Ca.
    That sounds like extremely lean jetting to me compared to what we used to run in the 600 and 628's. I think you have other problems. Try a new needle and seat(fuel inlet) and reset the float level. Also pull out the emulsifiers and make sure it is all perfectly clean. I think jets should be up in the 68/170 range or more if you have it opened up with exhaust etc.
    Ken
    Edit. Go to the dealer and order a factory service manual. It will explain how to set the floats etc. Stay away from Chiltons get the factory one.
  4. Moss2
    Mar 24, 2006
    Lincoln, Ca.
    Oops I mistakenly assumed that they had a carb similar to an XR600. I still dont see how they get enough fuel with that jetting. I would look for a 600 carb or Edelbrock to make tuning easier.
  5. Boston Mangler
    Jun 11, 2005
    San Diego
    Thanks Guys
    I have the factory service manual and see no mention of how to set the float.
    Also, all of the reasearch i have done online raves about the current setup i have (jets, desmogged, uncorked, etc.....)
    Its definitely NOT lean! :D that much i know!
Verification:
Draft saved Draft deleted
Share This Page
