10'' 2.0 3 tube king BP
Linestrange
Have a sandrail with a arm setup in front with King 10'' 2.0 3 tube bypass shocks, extended length is 27'' collapsed is 17'', can i move up to a 8'' 2.5 King 3 tube bypass with 3'' extended rods ends which will come out to 27'' extended to keep the suspension the same but run larger shock?
cosmo
Super Moderator
1,909
176
Why? It's a sand rail. You also have a coil over shock to work with. Thru good valving, spring rate (s), bypass adjustments, cross over settings, you should be able to make things work?
Linestrange
just trying to update the front end and help with resale value, most guys with the higher end sandrails are running 2.5 or 3.0's. on the front.
