2019 NORRA M1K Bronco Build
Radiobirdman32
Great looking build so far. Look forward to seeing it in person and meeting you guys at NORRA this year. Cheers! Armand
landshark
Working through the list of things to do, doesn't look like much has been done but we have accomplished a ton in the last few weeks. Currently wiring, plumbing and finishing up fabrication
landshark
Doesn’t look like much has been done but we have officially turned the corner on electrical and plumbing. Just missing a few connections for each, electrical is about 95% done and tested. I will go out on a limb and say we are two weeks away from firing it up. Maybe a run around the block.
As always when you fabricate or customize everything we are having to install - tweak - then re-install to get things where we need them. Very time consuming but worth it.
Gary Plagman
Keep up the Good Work.
How does’ it Look for the Time Line. And that shake down test!
Cold Day in Denver, last night Snow 7 deg
landshark
Hoping to shake down first part of next month. Was 0 degrees this morning at 7am. Probably try to run it down south of Pueblo or north Moab. Will depend on weather.
pre heat that oil!, looks good , make sure you take GOOD care of your race prep guy, broncos are ' fun' to prep.,lotsa room everywere.
bajaxp
Baja Bobsled Team
Positive build karma sent your way. Great job and keep hammering away. We need more of your great pics!
landshark
#35 is ALIVE! Started right up with the help of some fuel priming. Have a few gremlins but overall pretty solid so far. Should be ready to do a lap this weekend and then start buttoning things up for shake down and paint.
Pay no mind to the Chinese voltage indicator.. they are 1 volt off..
landshark
well, it runs, it drives, its a hand full on the street for sure. Its REALLY REALLY loud.
Here are some quick glamour shots, It's the nicest it will ever look for sure - hopefully get some more photos outside here soon before we get it dirty and start getting the numbers and other stuff on it.
We have lots of little things left but its ready for its first shakedown run this weekend.
landshark
She’s back after some outstanding testing at a secret desert test site near denver. Weather was outstanding, bronco was exceptional. Still have a list of tweaks and to dos but getting shorter fast. Look forward to meeting everyone in a month!
Rory
Crayola Killer
