2019 Racers 4 Kids/Laughlin Metro Santa Cops Fundraiser 10/11/19
locationsracing
Thank you Dina Cooper & everyone at BulletProof Diesel for the great donation of all the swag and the Gerber Utility knife and the Mechanics Fender Protector for this years fundraiser. Bullet Proof Diesel is always there for the kids and for everyone that wants the best product to BulletProof their diesel for the best performance
M Lewis
Thnak you METROPRINT NEVADA for making such great plaques for this years Racers 4 Kids Fundraiser these guys are the best for all signs, banners, plaques and signage needed for race, business or any occasion ??????????????
Thank you Danny for letting us be a part of this, we appreciate it!
locationsracing
Thank you Race Aid & Julie Boyer for the great donation of 2 Pink Radios for this years fundraiser, when it comes to great causes the entire Off-Road Family comes together!!!!!!
locationsracing
Thank you Riverside Resort Hotel & Casino for the Super Donation of a 3 day 2 night hotel stay that includes 4 meals at the Riverside Complimentary Choice Buffet and also 4 movie tickets at the Riverside Cinema 6-Plex. We couldn't hold such a great fundraiser without support from great companies like the Riverside Resort
locationsracing
!!!!!!!!!!!!!!!!!! 5.7LS Custom Built Motor !!!!!!!!!!!!!!!!!!!!!!!
Thank you Touched By Pro's for this great Auction Prize of the motor I am including the spec build sheet for this Awesome Donation. We will be posting pics of the build as it comes together for all to see. Hope to see everyone there Friday night Oct 11th.
Iron block LS
3.918 bore
349ci 5.7L (.020 over Ls1)
Billet Double Roller timing set
(Cam timing advanced 2° for bottom end torque)
243 Heads (milled .035) 59cc
(11.5:1 Comp ratio pump gas motor)
Cometic LS1 head gaskets .040 thick MLS
Ls7 OEM Lifters
Touched By Pros Camshaft
(Cam specs will be shared with owner)
Brian Tooley Racing .660 dual valve springs
Chromoly 7.4" push rods
Flat top pistons "Silvolite"
Moly Hastings piston rings
Stock rods
NGK TR55 spark plugs
Camaro oil pan+pick up+windage tray
Melling oil pump
Decked block
Line honed
Billet valve covers
Billet coil brackets (for D585 coils)
Billet valley cover (knock delete)
Billet oil dip stick
Engine block powder coated
Tiffany's Blue
Gold chrome billet valve covers
Gold chrome front & rear covers
Gold chrome oil pan
Gold chrome oil valley cover
Tiffany's Blue coil brackets
We are limited on time but plan on "Diamond Cutting" the edges of the valley cover, coil brackets, oil cap & edge of valve covers.
This is a engine we have produced many times minus the complete over the top custom finishes on this specific engine. The engine will produce over 540HP at the crank on 91 octane pump gas. All of our engines are assembled with "Driven" brand assembly lube, the same assembly lube used by Nascar engine builders. The assembly lube is stable, the engine can be stored for later use without the fear of a dry start up. All gaskets and seals are GM or exceed OEM specifications. This is a Naturally Aspirated engine and not built to withstand boost.
Touched By Pros gives a standard 12M/12k mile warranty in street use applications only. Boost, nitrous, off-road or modifications to the long block of this engine void all warranties.
