2wd 02' suburban lift
Mike_HKmtrsprts
722
2wd 02\' suburban lift
Im trying to lift the wifes suburban by the end of Jan. but this 2002 1/2 ton 2wd has torsion bars up front not coils and nobody makes a lift for it the avalance front end looks the same but no one will tell me if it will work on the wifes sub. does anyone know of a place that make s a good quality lift fot this thing and it has coils in the rear no leafs and im not gonna run air bags on it!!! thanks in advance...Mike
everyone thinks they are superman when the camera is pointed at them...unpill they land!!!
jeff
Moderator
7,434
325
Re: 2wd 02\' suburban lift
How much $$$ do ya got? CST has a kit but it ain't cheap. Rear uses a steel cylindrical spacer for lift. Front is just like a 4wd kit. PM me for more info about this or other kits that'll work.
You could also go with one of CST's 2wd 4" lift spindles. That and a torsion key lift can get you 5-6" inches of lift that's pretty easy to install and pretty easy to return to stock.
Aloha
