79 Ford NORRA Truck Build
john Mcc
65
48
We have shocks
john Mcc
65
48
Working on the X in the cage
One down and one more to go
7,261
3,945
We have shocks
when i got my new bilstiens, i kept them next to me that first night, 😍 , nothing like new racing shocks& new racing seats....( side note keep new shocks protected from welding splatter/ BBs, i had a couple land on my new shocks mocking up, left burn marks on the plating
7,261
3,945
Does anybody have any pictures of and or ideals on core supports????
lots of rubber!, dont solid mount radiator, two clams top and bottom, rubber, then rad,thats the tipp i got, make radiator actually Able to move around if in front, if you hit somthing, radiator can move & flex- shift around, plus solid mounting vibration can start cracking
john Mcc
65
48
JDDurfey
3,045
3,447
Are there rules that do not allow the rear part of the cage (B pillar) to be placed right behind the cab and not inside? Would this not give more room inside and possibly be easier to build?
Baja535
48
65
I'm not sure of the rules but it's worth looking into. An X behind the cab would help with leg room, etc.
Bro_Gill
13,082
8,097
I have seen cages built that way with mini-trucks that raced. As long as tubing size and wall thickness are met, should be no problem.
john Mcc
65
48
Well the "X" inside the cab is not going to work, just not enough leg room. just going to have the diagonal bar from the upper passenger side.
john Mcc
65
48
Master cylinders, MC reservoirs, pedal and the steering quicken-er are all mounted
Josh 8
566
710
It’s perfectly legal to do. I have score tag on this one. It’s not the best picture but you can see enough to get the idea. The picture is about the broken down foam in the cell. It was 5 years old and just mush in the bottom.
NIKAL
3,806
1,456
Jimmy Weitzel has built allot of nice prerunners and over the years I’ve seen a lot of trucks where he has built the cage & B pillar in the cab, but the diagonal bars are on the outside behind the rear window. This gives more cab room. Here’s a picture of a older Ford single cab he did and if you look close you can see one of the diagonal tubes. I think Craig Stewart’s done the same thing.
