9" axle trouble
bryce1988
Dec 2, 2006
17
apple valley, ca
i recently swapped out my open diff 5:29 stock 31 spline 3rd member FOR a 31 spline 4:11 spool'd stock case 3rd member.
NOW the problem, one axle will not go in the last 1/2" to 3/4". they had to be pulled out with a puller, but went back into the open diff all the way by just pushing them back in. now with the new 3rd member set up the right side will not push all the way in. the other side is perfect. i never took both axles out at the same time so i know they didnt get swapped left for right or vise versa.
do they require to be pressed BACK in?
loufish
May 7, 2005
801
113
Burbank, CA
Can you swap axle shafts? If so that will tell you if it's the shaft or the spool...The spool could be a little tight, are you wetting the axle splines with lube?
You could also have a slightly bent housing and the old open diff was loose enough it didn't show up until now with a tight splined spool...
Brock_Beeson
Feb 18, 2005
543
20
vista, ca
the axles are sided.. ones shorter than the other.. are the splines twisting or worn? old splines might not be true
Feb 19, 2002
6,706
1,534
Easton, KS
The splines in the spool are longer than the stock diff. This is causing your axle to bottom out on them and not go all the way in.
Feb 19, 2002
6,706
1,534
Easton, KS
Turn some of the splines out of the spool on the lathe. Make sure it has the splines running all the way through it first.......... You don't want to end up with 1/2" of splines.........
