let me add pbp that mark the owner of the car has the back drooped out with the axle at 26 degrees and you can spin the axle no problem.at one spot though it seems to have a hard spot,like it is binding but its not.the axle will still slide or plunge and has the same resistance as when it has 0 degrees.the droop stops have been cut off of the torsion housing and the spring plates are notched a bit.the rear has 14" foa's with the wrong rate but new springs are on the way.i just dont want him to go too far with the cvs and i dont have the buggy dork knowhow,thanks.
