air bags
Catman
Mar 23, 2002
24
Ramona, CA
Im looking for info on disarming the air bags in a 97 ranger I dont want to loose stock wheel it can't be permenent as truck is driven on the street .The truck has three fuses marked for air bags?
Mike_HKmtrsprts
May 3, 2001
722
Murrieta
by puling the fuses it wont deploy the air if your worried about that, each fuse is for the 3 sensor that detect when your truck is hit I had a chevy at it only had 2 I pulled them both and the airbag light came on and that disarms the air bag. Thats what the dealer told me to do. I would do the same on your anti-lock brakes cuz they can really get you in trouble in the dirt when trying to stop fast.
Jack
Apr 2, 2001
3,980
174
CA
I was thinking of putting in a switch on the dash and a relay (or a few) to shut off the airbags and ABS when in the dirt. It is a PITA to stop fast with the ABS in the dirt. The pedal just bounces and you keep going.
Josh_Bethmann
Mar 21, 2002
48
Orange County
Keep us posted as to how you do this. I would be interested in doing the same to my truck.
<A target="_blank" HREF=http://www.JTB-Design.com>http://www.JTB-Design.com</A>
J_Dog
May 14, 2001
610
Vacaville, CA
Catman, I would look into getting one of the switches from the later model trucks that you use a portion of the ignition key to turn the passenger side air bags on or off. You could then mount it in the dash somewhere for a clean looking install. The only problem would be you need to get it through a dealer (usually a little more $$$).
jeff
Moderator
Apr 1, 2001
7,454
352
California
www.performancelifts.com
And be careful when you start messing with the ABS system. I was going to run a switch to my ABS on my Dakota until I learned the transmission gets some of its lockup and shift signals via the ABS system and main brain. If I disable the ABS by pulling the fuses I've been assured by both the dealer and a bunch of other Dakota owners I'll fry the transmission in no time. My advice is to make sure it won't screw anything else up before you start pulling fuses.
Aloha
Catman
Mar 23, 2002
24
Ramona, CA
the truck is a 97 it has the keyed switch for the air bag ;I will have to get into the colume to ID wire that deploys bag. I am more worried about the accidental discharge than having it not work at all .I sure hope my abs is not tied into my auto trans , I was told the 8.8 diff wasnt all that great I dont want to spend the money on gears/locker if housing is going to spead I dont want to become an expert on 8.8 bearing/axel overhalls thanks for info,will post info on air bags only if Im sure it works
Jun 18, 2001
298
The 8.8 is great unless you plan on doing a 4-link or racing it. We have never had a problem with ours and it has 10k prerunning miles on it. Good gears, posi, and Ford SVO girdle and it's good to go. If it was a bad rear end it would not have replaced the 9" for production trucks.
<A target="_blank" HREF=http://www.animalhousedesigns.net>Animal House</A>
sbro
Aug 1, 2001
234
So Cal, CA
I have the key controlled passenger side airbag as well. I'm not familiar with airbag wiring, but would it be possible to wire it so that the key mechanism controls both?
<font color=orange><A target="_blank" HREF=http://www.desertrides.com>http://www.desertrides.com</A></font color=orange>
Marshall
Apr 11, 2001
394
central Cal
I have heard a few rally guys talk about putting ABS switches in there cars, Might want to ask on the rally board for tips? just a thought.
