Air bumps on a buggy??
daltonfixr
23
I was wondering what the consensus is on putting air bumps on the rear of a torsion sprung Class 10 buggy. We currently have a 2" Fox shock next to a 2 1/2" bilstein 4 tube bypass shock. I was told that installing an air bump stop would help the tunability of the rear suspension. I know that going to coilovers in the rear is the best thing to do but that is not going to happen until at least next year. I already have a set of air bumps from another project so this wouldn't cost anything.
WHAT DO YOU THINK??
Class 10 newbie
Mike_HKmtrsprts
722
with out a doubt I would run them even though your suppost to be able to set up a bypass like a bump stop it doesnt work like the real thing! and I have seen them on alot of torsion sprung cars but your right you need to run a coilcarrier to dial in the rear just right....Mike
<font color=red>The dump you take is the gold I make so I can afford to play and race!</font color=red>
factorX
10
You should be able to make a class 10 buggy work with a bypass shock, All a bump stop is, is a bandaid witch you dont need.
Off road race rental companion of the evening
michael_loomis
26,214
2,426
no save your time and money and dail in the bypass and play with the torsions. the are endless possibilities with torsions and bypass , the same as coilover and bypass. sure coilover has a slight advantage but torsions arent all that bad either .
rear or mid engine ? air or water cooled ? what size rear arms ? how long and what diameter torsion are you running ?
daltonfixr
23
Rear engine (type 1)
Air cooled
Not to sound stupid but what measurement would describe the rear arm? center of torsion to center of wheel?
The torsions are 29 1/2" long and 27mm
Class 10 newbie
AZmiik
288
Size of a longer arm is generaly stated as how much longerXwider than stock. So a 2X3 arm would be 2" longer and 3" wider than a stock VW trailing arm.
Mike
