Air bumps & shock stops
Muddi44
Feb 27, 2007
69
Wales UK
Is it ok to remove the rubber washer style bump limiter if fitting air bumps (the 3/8" thick rubber that stops metal to metal contact)
Tim
Random Thoughts Racing
Jun 6, 2006
1,004
81
Escondido, CA
Bumpstop tips wear, strike pads indent etc., this causes the upstop point to effectively raise with use. If you want to remove the rubber, gain maybe 1/4" more shock travel at full bump and run the risk of going metal to metal then sure, cut away.
Muddi44
Feb 27, 2007
69
Wales UK
Good point, decision made, they stay. Thanks
Tim
