aluminum vs steel hardline
landshark
Aug 27, 2018
193
376
Denver, Colorado
I am building a NORRA early Bronco and have the body off the frame so running fuel and transmission hard line on top of the frame rails to keep them out of harms way and out of the exhaust heat. I only had enough hard stainless steel line to run one length for the main fuel supply from the rear cross member. I had 25' of aluminum hard line on hand and used that for a return line for fuel (future EFI and redundancy) and ran two lines to the rear of the frame for the transmission cooler. The aluminum line is of course much more fragile than the steel line. I have been rethinking it's use and just wanted to see what everyones opinion was on using aluminum vs steel/stainless steel. My budget is tight and was trying to use what i had on hand but now thinking twice about it since i have access.
landshark
Aug 27, 2018
193
376
Denver, Colorado
isdtbower
Mar 9, 2007
328
230
Palo Alto, CA
I thought someone mentioned about dirt and crud building up on the top frame rails. I am not a mud guy but do think about letting sand and other drain from whatever. (Says the guy who just pulled out his flatty and the drum brakes were 1/2 full of dried mud.)
Bert is my name
Jun 20, 2018
906
341
San Diego
I'm probably stating the obvious but aluminum work hardens and will crack with movement and or vibration. I'm not sure that am off road vehicle is a good application of aluminum tubing for fluid transfer. Also ethanol is corrosive to aluminum. So I would not be using it for fuel.
randy68
#1 Enemy of Google
Jan 21, 2009
3,416
3,775
Chino Hills, Cal.
Don't even think about it....
