Automatic Transmission Dry Sump
Jul 16, 2009
15
Naugatuck CT
www.offroadcustomcreations.com
Is an automatic transmission dry sump possible?
Rock crawling puts you in some extreme angles I don't want to starve my transmission, I can feel it start slipping in the extreme angles even with it a little over filled.
Has anyone ever made a dry sump for an Automatic transmission.
I was talking with some people and they say the valve body needs to be wet (sitting in the oil). If that is the case I can just plumb the scavenge pumps higher in the transmission.
Any thoughts?
07FJRog
Feb 26, 2009
3,325
372
Tonopah, AZ
there many others that rock crawl with no transmission issues, don't know why you are.
1audiohack
Jun 18, 2009
21
Las Vegas Nevada
I have seen that done on a TH400.
They just added one more scavenge stage to the engine dry-sump pump and sent the oil to its own can. The pump intake was plugged from the bottom and an AN fitting welded into the outside of the case, connected to the can to feed the pump.
I can think of absolutely no reason the valve body would have to sit in oil.
