Baja 1000 Zero Emission Challenge
E motorsports
Nov 2, 2020
96
136
utah
Ideally, we'd go back in time and prevent the ICE from making its way into nearly every automobile. But its too late for that.
The sun radiates. We can use that radiation for heat, for visible light, for generating electricity, etc.
Electricity is the means by which we transfer heat and light across distances. Thank Allah for AC power.
actually Direct current is what occurs in nature
alternating current is pretty much man made
so Thomas Edison is who you want to thank for A/C
Tube ride
Mar 12, 2016
994
1,594
Las vegas
Inventor of AC power Nikola Tesla
cynicwanderer
Jan 10, 2016
367
399
Sacramento,CA
you know that PVs are even less efficient than ICEs, right ?
Bro_Gill
Dec 5, 2007
14,195
9,522
Big Bear, CA
So if you only drive , say, 100 miles a day (non-trophy truck!) can we guesstimate that you would need approximately 1 acre of solar to convert hydrogen to commute to work? How many homes in SoCal have 1 acre to spare for solar? Don't even try to say roof top will do it. In 2018, there were 15.1 million cars registered in California. If I guess low and say 1/3 of them are in socal, that means ONLY 5 million acres of solar just to power cars, not lights, computer, TVs, etc... How's that math workin' for you?
Jan 17, 2019
9,216
5,527
sandiego
bird scooters and trolleys, private autos are so 2020, its a green new deal world, some will fly around it in gulfstreams, others will be forced to dig ditches in it, guess what side We will be on💀
cynicwanderer
Jan 10, 2016
367
399
Sacramento,CA
yup, on top of that you'd need to store the energy you get during the day in a battery, so you can charge your Tesla at night. that's another 30-40% loss. I suppose you could get two Teslas and charge them on alternate days; in any case, charging your Tesla probably loses another 15-20% or so.
Argentino
Dec 6, 2020
39
65
Vegas
"The only real problem is the issue of safety. Hydrogen is highly flammable – more so than regular fuel – and is harder to contain than oil. This means that any car fitted with hydrogen fuel cells is a lot more likely to blow up or set on fire if it is exposed to extreme heat, if it breaks down or if it overheats."
Will the first vehicle be called "The Hindenburg"?
Jim Glickenhaus
Nov 23, 2020
57
163
NY
Total bullshit. The cytogenetic tanks we use are used in military aircraft. They are much safer in crashes. Can survive being shot and if holed ooze a foam that is 200 degrees below zero and neither flammable nor explosive. They can be refueled anywhere in the world 24/7/365 by any welding gas supplier for $1.50 energy equivalent of a gallon of gasoline. It can also be dispensed at existing gas stations. It is safer to store than gasoline.
Jan 17, 2019
9,216
5,527
sandiego
but but, they said that airships were perfectly safe too....
