Baja Designs New LED Strykr Adventure Light
Baja D "Diego"
Jan 29, 2007
478
17
Oceanside,Ca
Lifetime Warranty – We are so confident in our construction standards that we will warranty the light head for as long as you own it. The battery carries a 1 year warranty.
800 lumen High Output Cree LEDs that are custom sorted for us to ensure optimal color temperature and maximum brightness.
5700˚ Color Temperature – “Warmer Color” to preserve depth perception and ease eye strain
Water Proof to 33 ft – Silicon O-rings and seals, stainless steel hardware and custom overmolded connectors ensure you won’t get left in the dark no matter what the conditions are like.
Closed Loop Microprocessor – Proper heat management is crucial to preserve the life of High Output LEDs. Built in temperature monitoring means that the slightest airflow maximizes brightness and that the light automatically dims when stationary.
Oversize Optics provide greater lighting efficiency for incredible light output. Our textured reflectors have been developed to put the light exactly where you need it.
2 optics included – interchangeable spot and wide pattern so you always have the best light for the type of terrain you are riding.
High Quality Construction – Full Mil Spec and Dive standards throughout
Conveniently Located Switch with solid tactile feedback
4 Light Modes – High, Med, Low and Strobe
SIMPLE, INNOVATIVE LIGHT HEAD MOUNTING SYSTEM; NO TOOLS REQUIRED, NO BULKY CLAMPS TO CLUTTER YOUR RIDE DURING THE DAY. FULLY ADJUSTABLE IN PITCH AND YAW.
Long Battery Life – 3, 6, or 12 hours depending on light mode.
Battery Level indicator – Very visible glow is green down to 1 ½ hours then flashes green to 30 minutes, then yellow to 10 then flashing red. Automatically recalibrates if light level is changed.
Lightweight – Entire system is only 520 grams
Simple, Solid battery mount – no tools required, easy on/off.
Li-Ion batteries – the most current technology with an integrated charge management controller to give you the run time you need. Of course the battery is also waterproof to 33 ft.
