SteelShield
- 36
- 11
If you run a bare chassis in any type of racing or wheeling, you are going to experience rust. Surface rust, flash rust, overnight rust, whatever you want to call it, it makes your vehicle look terrible. Nobody enjoys seeing their vehicle covered in rust and oxidized metal. However there is finally a solution, Mavcoat Steel Shield!
Mavcoat Steel Shield is a corrosion prevention coating that prevents rust from forming on all metal components. Steel Shield is 100% weldable, dries to the touch, dries clear, and provides protection against all types of corrosion and oxidation for anywhere from 6-12 months. This product is perfect for all racers, builders, and enthusiasts alike. When a racer like Rodrigo Ampudia uses it, then you know it must perform well.
Visit www.mavcoatsteelshield.com to place your order today.
