Best hole saw size for notching, when mig welding?
singlehanded
Jun 3, 2001
1,584
Placentia,Orange County
I will be notching 3/4 and 1 inch and 1 1/2 inch dom tubing. What is the corect hole saw to use on each one to get a desired gap for mig welding.
THANKS..................
singlehanded
Jun 3, 2001
1,584
will it leave a gap? I think I used 1 5/8 last time I did my bed, but there wasnt really a large enough gap as I would have liked. Will 1 1/2(hole saw) on 1 1/2 tubing increase or decrease the gap.
GFC
May 22, 2003
307
Escondido
generalfabco.50megs.com
ok..... you do not want to have to weld ANY gaps. as for hole saws, if you are fitting a 1 3/4 in. tube up against a tube of equil size, use a 1 3/4 in. hole saw. when fitting a piece of 1 1/2 in. tubing up against a 1 3/4 in tube, also use a 1 3/4 in. hole saw. when fitting a 1 1/2 up against a 1 1/2 use a 1 1/2 in hole saw............. catch my drift?
sorry that it isnt a very clear pic
singlehanded
Jun 3, 2001
1,584
but you do want some gap when mig welding and no gap when tig welding. or else you will end up with a larger uglier weld mig welding material that is touching. Am I right or have I been told wrong.....
drtdevil93
Apr 5, 2001
1,766
11
fullerton, ca
a very small gap is good for mig. the problem is there wont be an equal gap all around. i usually use a 1.5" holesaw for a 1.5" tube, and grind around the edges to make a v-shape when its assembled.
erik
In_the_works
Sep 19, 2002
305
none
The attractiveness of a bead has a lot more to do with the skill of the welder as opposed to the presence of a gap or lack thereof. I usually prefer to have the tubes fit up against each other as tightly as possible.
Ryan B
Jun 11, 2003
356
10
sparks nv.
If there is a gap in the joint that means you are filling that with the welder. If there is no gap I think you are going to get better penetration between the two pieces you are joining because you aren't wasting any of the heat and material from the weld were there's no material. right?
FABRICATOR
Apr 3, 2001
5,146
108
Ventura County, CA
If you are that concerned with joint preparation and strength, why Mig weld it?
Ryan B
Jun 11, 2003
356
10
sparks nv.
If your life depends on that joint, like in a seat mount or something, then weld prep should be a big deal no matter what your welding with.
FABRICATOR
Apr 3, 2001
5,146
108
Ventura County, CA
That was not my point at all. Explained another way...To insist that a special fit is needed for Mig welding, is not congruent with the choice to use Mig welding.
Kbach66
May 9, 2002
605
14
Simi Valley, CA
Anyone have a good source for 2.5" ID galvanized pipe. I'm going to be cutting out all the DOM chassis/cage and starting over on my truck. From the website Jeff posted, it seems like I've been going at it all wrong. I'm thinking about selling my bender and notcher as well, seems like I should be able to rebuild it all without any bends and notches!!
Josh_K
Apr 11, 2003
768
9
Redlands, CA
Ya, there's going to thousand's of dollars worth of fab tools for sale in the classifieds soon. I wish I would have thought about doing it the "better way" before I bought my bender, a full set of dies, Tube notcher, plasma cutter,,,on and on.
MNotary
Apr 25, 2001
929
16
Melbourne, Fl
Early 90's at Crandon. ... All the GOB cars had iron pipe cages on the OUTSIDE of the car.... ssooooo cooooolll.... And there was a 100 of them...... I think some of the Class 13 (now Sport 2) had a little Iron pipe in them too....
michael_loomis
Jun 27, 2001
26,216
2,428
Temecula, Ca.
you silly people ... you dont want to use galvanized pipe !!!!
use ABS ...ITS MUCH LIGHTER !!!
