Re: BFG Baja 37\'s
"Project 1500, it doesnt matter whether your motor can handle it, anybody can gear something down and run 37 on it no problem, the question is whether you suspension can handle it. If you wanted, you could gear a pinto to run 37's. Gearing and motor are only a small part of the equation. To run a 37 right, you need to have a good set of spindles, steering components, and strong strong suspension components."
I got the suspension to handle the 37's, I got the gears for that tire size,and I have plenty of power.
So I am going to run 37's on a app thunder II 17x8 wheels. If you dont like it its ok you cant see it from your house.
Thanks for the heads up...
