robjs111
- 98
- 1
Setting up front suspension on my 96 bronco.
Details:
Stock width beams from desolate.
Shock hoops dedolate
3 x 12” swa coilovers
Duralast alcoas with 35” tires
Issue #1)
Right now I am getting 16” travel from bump (1/2” shock shaft showing) to shock fully extended.
Issue #2)
At full lock/ close to full bump, (drivers side wheel turned fully to right) top of tire is rubbing on coilover spring.
I know the 15” alcoas have a 3 3/4” backspace vs 17” wheels with 4 1/2” backspace.
Also tried different setting on upper ball joint cam.
Would moving lower shock mount further in away from tire create other issues? Not sure how to proceed from here.
Thanks
Details:
Issue #1)
Issue #2)
Thanks
