Buggy Brakes
McCredie A
Jan 29, 2008
780
383
Vista or Hemet, Ca
Buggy's have ran turning brakes for a long time. It seems in the last 10 years or so trucks have started using "turning brakes". Rear brakes hooked up to a similar style handle as a turning brake in a buggy.
I understand the difference between the spool of the truck and open diff of the buggy. I am wondering if any buggy guys have tried hooking up a turning brake handle that engages both rear brakes like a truck? What are the thoughts on this? Would it be a waste of time?
mxben
Jan 11, 2019
384
Solutions
486
Ventura County, CA
Not really to you're point but when you watch the in-car footage of dickerson that dude works the f*** out of that lever. It's pretty impressive.
E.Hagle
Mar 5, 2020
369
682
Somis, CA
Before driving a 10 car I would have thought engaging both tires would be a better option but after getting some seat time I wouldn’t trade it out. It does both high speed and low speed jobs in one package as opposed to the dual engagement really only working well with momentum and weight transfer.
Jan 17, 2019
9,707
5,913
sandiego
in trucks it seems all your looking for is to initiate ' polar moment of inertia', get all that weight to start rotating, buggys seem to need help to over come a throttle on ' push' with no weight up front& All the grip in the rear, i just remember my first car, baja bug , would wanna go straight in the least opportune moment😵😵😵
swiftracing5
Oct 13, 2006
2,630
2,206
Costa Mesa
In a buggy with a rear engine you don’t want rear (or front) skidding together. The weight transfer will spin you out. You see it every year at BAP infield.
michael.gonzalez
Mar 13, 2018
4,499
1,687
Camarillo, CA
www.facebook.com
Why isn't his co-driver wearing gloves? He went to all the trouble of the firesuit, helmet, skirt, etc and then cheaps out on the most basic safety stuff...SMMFH.
I'm pretty sure gloves aren't required in most organizations.
And also, touchscreens and gloves don't always mix well.
Jan 17, 2019
9,707
5,913
sandiego
or when they Do wear gloves , its those melty - to - your -skin plastic nylon ' mechanix' style gloves, 😖
Charlietuna
Nov 17, 2011
204
255
Imperia, CA
Fire doesn't really give a poop if they're required or not....and touchscreens don't work with scar tissue real well either.
They have million dollar equipment but ten cent thinking.
McCredie A
Jan 29, 2008
780
383
Vista or Hemet, Ca
Are you guys running cutting brakes? If so one or two handle? What is your thoughts on them and when do you use them the most?
cjohnson
Nov 19, 2018
244
272
Mesa AZ
Simple answer: Because the racing organization doesn't require fire-rated gloves.
This is not directed at you but does everyone need a baby sitter? If there is no rule they won't think of their own safety? This is why there are so many arbitrary blanket rules because people don't use common sense. Wear safety equipment when racing. If you've ever seen someone burned up it's not a pleasant sight. It does not take much exposure to turn a hand into a lobster claw.
E.Hagle
Mar 5, 2020
369
682
Somis, CA
Single handle just like the video. Couldn’t really imagine Baja without it. Transition into tight corners, pick up the throttle a lot quicker. Rarely using it as an aid above 50mph
