I can,t really tell but it looks like your lower heim on the center link is mounted vetically. I you are willing to spend a little more time you should mount the heim so it lays horizontially so that the bolt is verticle. This wiil help alot on a three link design because the lateral force pressed against the rear end while cornering is almost all transfered to the lower mount on the center link whick will try and push the race out of the heim.
hope this helped good luck with your project.
