Carlos' beamed Dodge Cummins
socalmoto
Starting new
Swingers
Knuckles
And the BEAMS
Ride height. Pushed the tires for much stuffage
And stuffed
Should have easy steering
mexracer10
way cool never seen an i-beam dodge and for sure never seen a cummins i-beam lol, whats inline for the rear? work looks real good so far.
socalmoto
the rear has deavers and 3.5s, but lots of plans for the truck ..... those plans will be later in the year though.
socalmoto
Boxed in the mounts today. Monday ill start sitting down for a few days and weld everything, then get to mounting shocks and engine cage.
Rad arm mounts
Beam pivots
Also got little gussets on the steering tabs too
Dezertpilot
UNreal...so badass!
Dirty Harry
That is rad! Can't wait to see the finished product. What shocks are you going to run up front to control all of that weight?
socalmoto
3.0x16 c/o, 3.5x18 bypass and 2.5 bump .....little miss matched on the colors right now. Blue 3.5s were already in the rear with deavers.
Got some stuff welded. Still need to weld the pass side radius arm mount, steering mounts (will wait till tierods actually cycle), and a few gussets and pieces here and there. Hopefully steering will be welded and finished before the weekend.
Finally got a mig going on this project. I was 100% tig, but WAY too much welding in a short amount of time.
socalmoto
Heres a good pic of him jumping with the solid axle. And remember, those are 37s on the truck, not 33s haha
socalmoto
Got the steering going today.
Carlos got some nice psc stuff to put on as well. Theres more then just the ram assist
socalmoto
Decided to move the ram onto the swinger instead of putting it on any of the steering links
Camber and caster is now set. I fiddled around with the steering a little more today and everything is set. Everything clears full bump and steer. So after some welding during the week, ill start on the shock hoops and engine crossover. Ride height
Bump
Also added another side plate to the driver side mount
Chris Tobin
Awesome work!!!
