Check these out made in Australia.
biffgnar
507
319
IIRC there have been some big threads over on Pirate about that stuff. Might have been a lot more talk than actual use though.
dirtslinger
708
599
You'll have to change the rotation of your motor or transmission, these turn the opposite direction of the US stuff.
mrlentle
853
854
Just like our toilet flushing direction down under?
Proformance Motorsport
36
Running in reverse if different to running upside down. Our diffs do not run in reverse, they use conventional Dana 60 and Dana 80 gear sets.
There is a case study explaining the disadvantages of running diffs on the COAST side of the gear set (Different to running upside down, where they still run on the drive side - BIT confusing for some...)
9" and 10" gears have a UNIQUE gear pattern than makes them VERY strong when driven on the drive side, but when they are run in reverse, the gears are much weaker and try to tear themselves apart.
Click Here for the link...
I have seen a lot of mid mounted cars running massive (EXPENSIVE $$$) 10" gear sets in the rear, running them in the wrong direction (COAST SIDE) - making their drivetrain much weaker. The correct thing to do is to run a reverse rotation (Vee Drive) to correct the rotation at the pinion and run the diff on the DRIVE side, where it is the strongest. Hope this helps explain it???
36
Our customers are building their rigs for some time now, you will see a 3 x National Champion running our diffs from Feb 2016 and others later in 2016 or 2017.... watch this space...
