Chenowth rear arms w/ bus stub axles
volks 73
I'm replacing the wheel bearing and races, when I took it apart I noticed the outside had a groove that looked like a snap ring would go in. The inside looks exactly the same, but it had a snap ring in the groove.The groove is about 1/16 behind the bearing race, the bearing can be removed with the snap ring installed. I'm thinking I should install snap rings on both sides, but I'm not sure I see a purpose for them. Does anybody recall this set up.
volks 73
I called precision alloy, looks like these are his bearing housings. He gave me a 10 min. class on the phone, and set me straight. Thanks for pointing me in his direction.
