Class 10 clutch question
BuffaloBanger
Oct 28, 2018
15
17
Escondido, CA
I'm about to replace the clutch in my class 10. Running a DI Ecotec w/ Mendy 2D. The clutch that came in the car is a stage 3, 6-puck, single disc. Curious to hear what other people are running. Should I stick to the single disc? Move to a dual disc?
Zac Reish
Oct 14, 2008
3,083
3,075
riverside CA
Keep single so it can slip. The 2d transmission is going to get hammered as it is running a di in a 10 car.
clogking
Mar 19, 2003
571
132
Solvang , ca
I use the Kennedy stage 3, 6 puck myself. Never failed me yet. Curious how many races do you run on your clutches or how far ?
BuffaloBanger
Oct 28, 2018
15
17
Escondido, CA
That's what I've got in there now. Only got the car a few months ago. First race (Cholla 250) I burned the clutch up 80 miles in. Will probably try to do 6 races a year.
drofmij
Feb 25, 2014
294
300
Parker Dam
I tried the dual disk as I had heard of guys breaking out the center of the single disk. Well the dual 8” disc clutch doesn’t have hardened centers. So I broke a disc. I am back to a single 9”
SMS81
Jan 16, 2008
361
447
CA
That transmission should go before the clutch! Something was not set up correctly or stop resting your foot on the pedal.
Deviant
Jun 29, 2011
30
58
CO
Kennedy Stage 3 single disk works Awesome with our ecotech. And heavy class 10 car. 3160lbs.
Keep off the clutch. The engine has tons of tourque. Just let her lug and she will pull out of it.
swiftracing5
Oct 13, 2006
2,671
2,251
Costa Mesa
Amen on the Kennedy. We’ve got the PCI 300 and Baja 1000 on ours and still feels fine. We change every 1000-1500 miles
racetrash
Jul 29, 2003
287
177
landers,cal
I always check the numbers between the disc surface and pressure plate surface...local shop I work with up here does it (RamcoRacing)
Bert is my name
Jun 20, 2018
906
339
San Diego
If the clutch is engaging at the bottom of the pedal travel and not towards the middle to top of the travel it is probably not disengaging all the way. This might explain the short life. An improperly set up clutch will trash thrust bearings in an engine as well as tear up a transmission.
BuffaloBanger
Oct 28, 2018
15
17
Escondido, CA
Found the issue. I replaced the clutch with another Kennedy stage 3. Went to test it, and while I had it in first with clutch pedal in, it acted as if I had let the clutch out, and immediately after, the clutch pedal was limp. Zero resistance. Restarted and it did the same thing. Opened up the reservoir and I couldn't even identify what the fluid was in there. Chunks of rubber floating around as well. So I rebuilt the master cylinder, replaced the slave, and flushed out the entire system. Works great now! Maybe I'll look into this "race prep" everyone's always talking about...:D
