Here some specs on the car
105 in (266 cm) or 120 in(305 cm) Wheelbase
93 in (236 cm) or 85 in (216 cm) track width
2300 lbs (1043 kg) dry 2800 lbs (1270 kg) race ready full of fuel spare tire, jack, tools etc...
19 in (48 cm) travel front and rear
Car can be setup rear or mid engine
Mendeola, albins or Fortin trans
The car is either setup for Chevy wheel bearing assemblies or for standard off road hubs with use VW wheels. My car is set up with the Chevy setup and we haven't any problems with them with over 2000 race miles. This is a nice inexpensive setup that allows you to use standard six lug wheels (i believe they are 6x150mm) I don't even use beadlocks. The calipers are standard Wilwood calipers with standard rotors. The only problem with this setup is it requires machining a rotor hat but is a simple part. The whole setup cost 1/4 of the "offroad" set up.
