Yeah, Scott I agree with you a 100%. No this is not a hv pump. It’s billed as a high pressure pump. Look up John Kaase oil pump. This guy is the 460 guru. It’s a cool pump as it has two inlets to feed oil. On top and bottom of the rotor/gear. It has improved the pressure about 20 psi. The old pick up was 5/8 id and the inlet port of all the pumps are 3/4. So I made a new pick it tube that is 7/8 id to make sure this was not the choke point. The screened area is twice the size too. And the pick up is 1/2 an inch off the bottom of the pan. With all this I figured I would have it licked it and it’s still has low on pressure. I want it over 60 psi.
Here is a current pic.
And buy the way, the windage tray has not helped a single bit.
So the history on this this began when I lost the drive line after my big wreck at NORRA in 16. That was a cheapy short block that I used in that race when at the last minute this engine dropped a valve 10 bays before NORRA. Here the engine 10 day before NORRA 16. Btw, Remember the 5 month build is did to get there! I start building October of 15. That was stupid crazy.
I had the heads fixed in a week. See below.
And slammed a short block together with 3 days to go till NORRA. See below. The wrencher is mike Backholden. Super famous off road fabricator with tons of wins and championships. No joke. The other guy is Abel Velazco. Tons of 1/1600 wins and championships.
Well this engine ran great. We used the old oil pump that came in this current engine block. It’s the one the truck came with. Ran great and good oil pressure.
Well then about 100 miles out of la Paz running 8th overall I ran out of talent and did this at about 105.
I then put it all back together. Took it out to couger buttes. I soft peddled the throttle for about 5 minutes warming the truck up. The first time I romped it and grabbed third at about 80 on a smooth dirt this happened.
The drive line came out with such a hard hit it broke the trans case and engine block. The engine got slammed so hard I found the oil pump in the bottom of the oil pan. Since then I have had oil pump issues. So to be clear the engine that was in it at the time the drive line spit out was lost. That was the same engine that I used in the NORRA race. The engine block I bought the truck with is the one I am back to and it’s the one that dropped the valve 10 days before NORRA. This engine block has been to dugans twice since the valve issue and looks good. So all the issues began with the loss of the original oil pump. At this point I just don’t know. I am going to check the front plugs tomorrow. Maybe I brain farted and don’t have the thin plug on the right side gallery.
The run stand sure comes in handy.
If is can’t figure it out I am going to go to a external pump.
