MTPyle
- Joined
- Oct 8, 2018
- 3,526
- RDC Crypto
- 7,481
- Location
- Draper UT
- Website
- www.eleusisdigitalcanvas.com
So one of the things we have had on our list is to upgrade our cooling lines on our truck. Not a lot of conversation on here about the pros and cons for hard lines vs hose lines.
Originally it had almost all steel hard lines but we changed to aluminum in the tunnel and up in the engine area leaving the steel down low where it can get hit with rocks.
We are thinking of going to AN braided lines for simplicity and less points of failure. Currently we have a crap ton of silicon and hose clamps.
One of the challenges is we need sensors in the line so we will need to machine a custom sensor tube in the output side.
We were going with -20 steel braided on the suction and -16 poly braid (for weight) on the pressure side. But after talking to Meziere we are going to use -20 on both sides. Currently we are 1 1/4 on both sides so I don't want to go less and make our flow worse.
Each side will be about 13ft of lines and at least 2 90 fitting on each side.
Has anyone used hoses instead of hard line? The parts are more for hoses but less labor so I think hoses will be cheaper and in theory better flow.
Here is a pic of all our lines out of the truck. LOL what a mess. You can see why its been on our list of upgrades.
Also I think our radiator was plumbed backwards. We jsut left it the way it was from when we got it and the output of the engine was going to the bottom of the radiator. No wonder it was so hard to get air pockets out.
Mike
Mike
