crumbling infrastructure
Jan 17, 2019
10,973
6,644
sandiego
taking a survey, the city started this wind an sea pump house repair job over a week ago im asking how long you all think it will take a public works entity to finish??, ( ps, i did 4 plus years of bridges- box building for otay rivers const., i know how long it should take)
Jan 17, 2019
10,973
6,644
sandiego
i say a week max,( private concrete co.) if non structural, i looked at it instead of the surf( flat), and its like a used car you bought with bondo& chicken wire,Ugly!, they dug out a bunch of bad rebar& concrete, now they exposed big voids under the side walk.it could be about till december im guessing
Jan 17, 2019
10,973
6,644
sandiego
probably its in the first part, e&e, then an engineering / bluprints phase, then sent to open bids, then bids go through the political phase, ie ' minority women owned concrete company?, then the bids get lost, by then rain has Really undermined sidewalk, And has compromised street integrity, whole street now closed off, new examination& evaluation required & a new engineering package re submitted, new bid request sent out,,, see a patern yet??
Tom_Willis
Oct 2, 2001
2,967
1,139
oak hills
#they dug out a bunch of bad rebar& concrete"
Did it look like concrete spalling and oxidation (from salt air exposure & lack of maintenance) or because of poor quality concrete & sloppy construction practices? That building collapse in Miami caused lots of videos to be uploaded that showed years of damage that was ignored.
Jan 17, 2019
10,973
6,644
sandiego
settling/ moisture intrusion, / plus a metal hand rail pocket failures( moisture damage)whats funny is i noticed this years ago,& chunks of failing concrete were being held in place only by the 500 layers of paint!, that pump house has Lots of graffiti history
JEFFRPM
Non Sugar Coated
Jan 7, 2008
1,969
1,130
Under the Tetons
It should have been sent out to bid........with a performance clause every day after quoted finish date is a grand penalty.
Oh wait that means 'change order' = more $$ & time
Tom_Willis
Oct 2, 2001
2,967
1,139
oak hills
That's something I noticed when I worked for the gubmint. Nobody cares about any project once it's finished and the mayor's speeches have ended.
Bro_Gill
Dec 5, 2007
15,147
10,598
Big Bear, CA
You sure a car didn't go off that? I see a brocken metal hand rail that does not appear to be an age failure...
Jan 17, 2019
10,973
6,644
sandiego
no, it is a , was a about a 6 inch stem wall 6inchs above side walk elev. that had post hole pockets for a gouted in steel hand railing, , big chunks of concrete were exfoliating on the stair / west side,
Jan 17, 2019
10,973
6,644
sandiego
water is 56 deg.scripps pier, global Cooling,
Tom_Willis
Oct 2, 2001
2,967
1,139
oak hills
Was it built post-Depression under the CCC program? Just guessing, but the era of the construction (and who did the constructing) can tell you a Lot. Kinda embarrassing that 20 centuries ago the Romans built poop that still stands.
Tom_Willis
Oct 2, 2001
2,967
1,139
oak hills
There's an inherent problem with rebar. Using vinyl coating, galvanizing it, etc., still isn't perfect because it gets nicked during the install. Years later, the rusting begins and then the expansion (and separation) are inevitable. I've heard of stainless steel as a substitute, but until it's close in price.....
