Bobby Rice
Hey everybody.
I’m in need of some help with a tricky situation with my custom built f150 8.8.
For starters, it has custom 33 spline billet end (c-clip eliminator) axles, explorer disc brakes, and a Detroit trutrac LSD.
I pulled the axles since the seals were leaking pretty bad after my first test trip to learn that it uses SET20 bearings from a ford 9”. For whatever reason, there was NO seal on the outside of the bearings. I had the old bearings pressed off and new USA made SET20 bearings installed to find that when I try to re-install the axle, both sides stick out about a 1/4”.
I have little knowledge about rear axles, let alone this custom ass shiii. If you have any advice or can point me in the right direction, I will be forever grateful.
