D44 Beams and Camber adjuster help
EOR1488
Aug 31, 2005
1,225
219
Albuquerque, New Mexico
We run a Giant I beam with D44 beam ends on camburg spindles. We have had nothing but problems breaking camber adjusters. Just wondering what others might be doing or what’s working.
85yota
Oct 1, 2005
378
78
Santa Maria, CA
Can you run a 0 degree bushing and have proper camber or what degree cams are you running now that are breaking? If you can run 0degree maybe just machine some out of 4130 and run a straight bolt. You could even weld it to the beam at that point.
EOR1488
Aug 31, 2005
1,225
219
Yeah I was thinking about machining something from billet. Using like 4 degrees right now though.
BTFfabrication
Mar 5, 2019
101
135
Upland
There’s also the option of using fabricated spindles with uniballs instead of bj’s. Then you could weld in a 0* cam in the beam (like tommy said) if your spindles are built to correct your camber.
KTB Racing
Jun 18, 2014
54
35
Menifee
What type of camber adjusters are you using? Ive never had good luck with the adjustable 2-piece ones. I figured out how many degrees I needed and ordered non adjustable 2 degrees and haven't had any issues. Also, check the gap between upper and lower BJ. If its not right the adjuster wont clamp onto the BJ taper correctly and always end up coming loose. Shouldnt be an issue if you have billet ends but it's something to check.
