dodge class 8 build
bullock1
IT'S ALIVE!!!!!! Got the 5.7 HEMI to fire today after 9yrs just took some Wyoming jerry rig and a bottle of 101 Wild Turkey!!!!
bullock1
So! It’s been about 18months since my last post. The truck is about 90% wired, the brakes are all plumbed, the steering is all plumbed, the rear end is fully assembled, the cooling system is plumbed mostly, still need to build some mounting brackets but we have been able to run the engine up to temp a few times now, the driveline is ordered and should be here next week along with the sway bar. If all goes well I hope to be driving it under its own power in the next few weeks.
pwerwagn
Glad you’ve made progress! I dig this thread up every few months to check for updates.
Lookin good!!!
bullock1
Got the driveline built and installed, we were able to drive the truck around a few weeks ago. We removed the 35 gallon fuel tank and had a 70 gallon built, so we are reengineering the back half of the truck.
Can i ask a question on the suspension and how this is a class 8? I thought the rules were has to use stock mounting locations? Sorry new here and trying to understand the break down of rules. I am getting to think Class 8XXX is has to use a frame and same make motor as in the vehicle, after that hog wild?
bullock1
bullock1
Front suspension must be of same configuration as originally installed from factory (arm/I-Beam)
Rear suspension is open, can have leaf springs, coil overs/four link, travel is unlimited as long as the tires come inside the fender wells.
Pretty much per the BITD rule book.
But would the suspension here be a "J" arm or still conisdered "a" arm. That is the part that was throwing me.
So by BITD could you center mount a "a arm" like stock and still be class 8 legal?
bullock1
Per BITD which I called several years ago when we first started building this truck they said they considered a J arm an arm and it was legal! I hope that is still the case, if not I guess we will run Trophy Truck. Not sure what you mean by center mounted a-arm?
bullock1
We designed this truck after the Greer’s class 8 Dodge that Kent Kroeker bought. It had a j-arm setup and they raced class 8 in BITD and Score for several years.
@bullock1 I looked at the rules and it looks like they updated it?
The rule basically is: SUSPENSION COMPONENTS: Tires must retract inside of fenders.
- SO that means kind of WIDE open then correct?
That’s how I read it as well!
Just saw this build good to see another dodge being built. Keep an eye on front upper arms had a similar arm design in 07 which folded up under breaking at Laughlin causing our only DNF and points championship. Ended up adding plate with tube and mono ball was horizontal. I'll look for pictures. Glen
