Don't laugh...E150 power options...any?
westco
Oct 11, 2005
225
14
pauma valley, ca
Hey guys,
I just bought a 1996 E150 Chateau 8 passenger van...one elderly owner with 100k...extremely clean..with all the paperwork since new...I also have the original window sticker...van has the 5.8 with 3.55 gears and a limited slip...I will be using it to tow our Toy Hauler and was wondering if anybody has used any programmers or chips for more power.
Thanks
JP
06dak287
Feb 3, 2009
249
Henderson, Nevada
im sure it shares the same controls as other 5.8's like the broncos. i would search around for some bronco tuners and see if they can cross over to yours.
Feb 19, 2002
6,797
1,639
Easton, KS
Bronco and F150's of the same year will cross over parts wise. Re-gearing would be the first thing on the list. With an E4OD transmission you have a fairly tall OD. You can get away with a lot deeper gears and still have good freeway cruising ability's.
philofab
Powered by Optima
Jun 13, 2006
1,921
407
JRod's livingroom.
Headers and removing the factory air intake mufflers with a drop in K&N does wonders for these vans. We did a Magnaflow muffler on our shop van and it helped too. X2 on gears!
westco
Oct 11, 2005
225
14
pauma valley, ca
WOW!!! I just pulled it off and what a significant difference it made....not that I will be doing this but...it spun my tires in 1st and smoked them in reverse. Climbed the grade up my road with a lot less effort...just pulls a lot better overall...we'll see how it affects my mileage, I guess it should improve.
manicmechanic
Dec 11, 2005
964
149
Washington
I have been told that the injection is aiming at adding only enough fuel to burn the air "02" so if you put in more air then your gonna hafta put in more fuel. Though I do hope your mileage improves.
westco
Oct 11, 2005
225
14
pauma valley, ca
I guess your right...it gave me a code P0174 "running lean bank 2"...how do i go about adding more fuel for the increase in air.
roser
Sep 1, 2009
7
Cave Creek, AZ
You may have unmetered air entering through the PVC system or restricted injector(s) on that bank. Maybe an intake gasket leak.
You might even try to reset keep alive memory and allow the MAF/Baro to update with a few sustained, heavy accelerations.
westco
Oct 11, 2005
225
14
pauma valley, ca
So the removal of the intake muffler/snorkel may not be the cause of the code?...I erased the code...without disconnecting the batt and drove it hard to see if it came back..it has not
roser
Sep 1, 2009
7
Cave Creek, AZ
If the intake snorkle mod was the cause, I would expect to see both banks lean with codes P0171 and P0174.
Feb 19, 2002
6,797
1,639
Easton, KS
Those have a mass air flow system, they are pretty flexable but it may take a while to adapt to the new equipment.
If it were the older speed density set-up you would have issues.............
westco
Oct 11, 2005
225
14
pauma valley, ca
That's what my understanding was...when i pulled our trailer up the grade from Rincon to Valley Center, which is a steep climb the first time was at about 25mph WOT...this weekend it cruised up the same grade at 35 at about 3/4 throttle...big improvement...I guess we'll see if it adapts.
manicmechanic
Dec 11, 2005
964
149
Washington
There is some power on the table with air intake. An example that I remember was asking a chrysler engineer why the dakota 5.2 was rated around 30 horses more than the grand cherokee 5.2. Hood clearence! smaller snorkell, the only difference.
Baja Fool
Sep 10, 2007
1,869
480
Cohabuzo Junction/SoCal
For a programmer try this: http://www.summitracing.com/search/year/1996/make/FORD/model/E-150-ECONOLINE/Department/Ignitions-Electrical/Section/Computers-Chips-Programmers/Part-Type/Computer-Chips-Modules/?Ns=Rank%7cAsc
It plugs right into the ECU....if you've pulled of a number of smog pieces, it may not load, from my experience. Sensors not talking back to ECU....
Then you may have to go with the chip: http://www.jegs.com/i/JET/561/89611/10002/-1
Good luck
westco
Oct 11, 2005
225
14
pauma valley, ca
Thanks Bajafool,
Neither one of the links work and I cut and pasted....said did not match any documents...what was your experience from either one of these?
