drill size
Ryan B
356
9
application dana 44 ttb spindles.
new wheel studs 5/8 with a .6850 knurl diameter
about how many thousandths under .6850 should i machine the factory wheel stud hole so it presses in properly?
Allen Bolt
21
According to Dorman between .017" and .027" under.
steveG
1,961
87
The spec catalogs used to give the diameter of the knurl and the bore that it was intended for. I don't know if that's still given, but it's worth looking.
RocketMan
418
16
found this on morrosos (sp) web site
No. Description/Application
46150 Wheel Studs—7/16"-20 x 2-7/8" Press-in, .480" dia. knurl and quick start dog end, fits most late GM drum brake applications. Standard hole size: .472" to .479"
46160 Wheel Studs—7/16"-20 x 2-7/8" Press-in, .560" dia. knurl and quick start dog end, fits most late GM disc brake and early drum brake applications. Standard hole size: .552" to .559"
46180 Wheel Studs—1/2"-20 x 3" Press-in, .615" dia. knurl and quick start dog end, fits most disc brake Fords front and rear and Chrysler front. Standard hole size: .606" to .613"
46185 Wheel Studs, 1/2" -20 X 3" Press-in, .594" dia. knurl and quick start dog end, fits 1979-03 Mustang. Also has flat on head for front hubs with ABS. Standard hole size: .580".
46190 Wheel Studs—1/2"-20 x 3" Press-in, .685" dia. knurl and quick start dog end, fits most Chrysler rear with 1/2" stud. Standard hole size: .676" to .683"
46220 Wheel Studs—1/2"-20 x 3" Press-in, .563" dia. knurl and quick start dog end for use in 1/2" Frankland hubs. Standard hole size: .554" to .561"
46240 Wheel Studs—5/8"-18 x 3" Press-in, .672" dia. knurl and quick start dog end for oval track applications. Standard hole size: .663" to .670"
Chris_Wilson
3,277
1,301
Err on the tight side. I've got one that's loose now.
