Dry Sump
randy1123
755
96
Who is running them and why?
Who's is the best and why?
Does is give more HP?
It may be a dumb question to some, but I looking for opinions.
JRod
fast-aid.org
6,147
704
dailey engineering = best in the world....and built in the good ole USA.
At least TRD thinks so.... As well as several other HUGE race teams in all forms of Motorsports......
......and PDailey makes hid appearance in 3......2......1.....
ProLite13
970
16
Most teams are using the dry sump system I beleive.
Dry sump system seperates the air bubbles in the oil through baffles also less drag on the crank = more power and constant oil to the motor no matter how it's bouncing around.
jmason912
211
Peterson makes a complete Honda system. Also allows you to run the PS pump off the back of the pump and eliminate a belt. Uses an aftermarket dampener such as ATI. I can have the electromotive timing wheel added to the back of the dampener and eliminate the distributor.
More than anything if gives you reliability. HP increase in single digits at best.
cdc12372
20
If you take a wet sump engine and change it to DS with no other changes, I agree.
If you make the propper changes to your engine your HP gains will be deep in the double digits!!!!!
jmason912
211
With a 700-800hp Pro2 or Pro4 motor no doubt, but with a maxed out limited venturi 1650cc 4-cylinder engine, not likely.
