Drybreak
Dustino81
Jun 29, 2018
113
138
Ft. Lewis WA
I recently had the redhead on my dump-can rebuilt prior to V2R. However I have had issues with it sticking open, not closing and causing a fuel spill (see attached pic). I’ve never had this issue till recently, someone had mentioned they need to be lubed ? Any insight is appreciated. Thanks!
dan200
#BSF200
Aug 28, 2007
16,159
8,646
Tempe, AZ USSA
They are rebuildable also. Never done it but I have sold a lot of kits for it.
Tube ride
Mar 12, 2016
1,360
2,329
Las vegas
in one of those pressure pro videos the guy Vince had a hand held grease cup coupling that you just push it down on the dry break a couple times to grease the o ring before the truck gets to the pit . It was in the video about the dirt flap that goes on the fuel cell filler.
Jan 17, 2019
11,028
6,698
sandiego
just remember there is Lots of gritt in the BaJa, it also loves Vaseline, keep a bag over fueling probe, And cover the truck receiver too, somthing that can be pulled off quick by the fueler
Fourstroker
Jan 14, 2004
5,143
1,381
Garden Grove, CA
^^^^ Lots of the newer TT's have flappers that are easy to move out of the way. Fueled a couple that had a piece you had to remove and then put back on. With fuel being the limiting factor on pit stops these days this cost us 3-4 seconds each stop.
El Mamito USMC
May 25, 2011
2,169
374
A Marine in the US Army
El Mamito USMC
May 25, 2011
2,169
374
where did you lube it and with what? i want to make sure i avoid whats happening to you
Dustino81
Jun 29, 2018
113
138
Ft. Lewis WA
I used Sil-Glyde,, and greased all 3 O-rings (see above picture) seems to be working fine now, I will be replacing them with the IMS viton o-rings soon ($20) and will make a habit of greasing them regularly
El Mamito USMC
May 25, 2011
2,169
374
Lube all of the orings with vaseline. You will need to open it like shown in the first photo
i actually lube the metal part the one where the o-rings go. but ill get some vaseline and also do the rings to be safe.
thanks for the tips
