I have a truck that has some euro hella H4’s in it. mild 55/60W bulbs in them. They are wired through a 30A relay. One for each circuit, total of two. The relays are powered by a common 10G wire and share a common ground. The issue I’m having is:
The low beams are kind of dull, a bit yellowish at night. High beams are nice and crisp the way they should be.
Voltage is only .1 off at the lamp bulb plug from what it is at on the relay on both circuits.
Both left & right are the same. Each light plug has it’s own ground and everything is fresh, high quality components, hwr..
Any ideas? I’ve experienced this before on other builds and haven’t found the reason or solution.
Any insight would be appreciated.
