.DXF for 40 spline
Jet109
86
Hi guys,
I have some drive plates here I would like to EDM wire cut out to 40 spline. Does anybody have a .DXF or .DWG they would be willing to share ?
Phil@digrite.com.au
Thanks!
Mark Newhan
4,566
2,590
I don't have a file.
I will say that those appear to be Speedway Engineering drive plate that are 24 spline. These are used with Grand National hubs with 2.5" bearings. The axles that we use in TT rear ends are either the big 40 spline (rarely used anymore) or 36 spline. Both of them will be too large in diameter to use in those drive plates. Also, TT axles won't fit through a 2.5" snout.
There is a small 40 axle. I have attached a resource that may help you.
Axles-Home
Also, try the link below. There is file sharing on this site.
Trails Less Traveled - CAD Library
Good luck!
