The setup im building will use a vertical heim joint at the top of the spindle, and a horizontal uniball at the bottom, so that steering will be the limiting factor, not the wheel travel (except the lower of course). A picture of this type of setup can be seen here:
or more specifically
also, on the lower part of the spindle, i plan on running a horizontally mounted uniball/spherical bearing. This mounting is a tight confine so it looks like a 1" would be the best bet. It will be similar to the following pics where you can see the horizontal uniball all the way at the bottom of the spindle (hard to see i know, sorry about that).
But here is the interesting thing. If you look realllllly closely at the total chaos spindle it is a normal toy spindle, but all they did was move the location of the ball joint to above the mounting point on the spindle, and correspondingly extended the mounting point for the upper arm up 3.5 inches. If you have ever taken apart a stock toy spindle, its pretty surprising but that entire stock ball joint could fit in the spindle from the top if there was no ream, and the hole was straight. All i need to do is drill and tap the lower out then make new lowers that will allow me to mount the ball in them, and while it should provide a decent amount of travel, the number wont be huge, the key part is that using a setup like this creates a lift spindle which allows one to keep the arms horizontal (parallel) to the ground so that all the energy is in the y direction, nothing wasted in the x direction.
and
as well as
I am probably using a 7/8" upper heim with a 1/2" hole and a 1" lower uniball.
here is a pic of the arms even with the ground
wondering why no one else has made lift spindles like this?
and
as well as
