Wicked Al
This thread is to discuss electric builds and anything technical related to electric racing. It is not for political discussion about energy policy or other personal opinions about going electric. This isn't even about green, it's about taking advantage of the pros of going electric and addressing the cons of going electric.
I am starting a build for racing KOH so this is my primary topic. I expect to do desert racing and WORCS with it too at some point, but for right now, primary concern is KOH. I am not one of the teams gifted with a drivetrain, this will be of my own design for both the drivetrain and chassis. There are advantages going electric provides that ICE can not. The EV packages given out I would consider Gen 1 technology, I am developing Gen 2 technology.
Gen 1: Swaps an ICE drivetrain for an electric drivetrain
Gen 2: Other things which I am not going to talk about now, but as I get IP secured I will.
Here is the basic structure of the vehicle:
UTV class. RS1 style single seater. 72" wide, 90" wheelbase, 4 motor, 4WD, 200hp (250 or 300hp option if testing determines it's needed), 23" min front wheel travel, 25" minimum rear wheel travel, 35" tires, 95mph top speed, 1888ftlbs torque, 40kWh hot swappable batteries. It will have my Cross Link suspension, anti feedback steering and .... other stuff.
No CVT's will be hurt in this build, unsprung mass will be acceptable, scrub radius, KPI, caster, camber, bump steer, track width delta will all be controlled and, if you look at it long enough, will be downright beautiful.
It has already been named, we call it, Rock-E.
I am not an EV drivetrain expert. Inverters, vehicle control units, battery management systems, Can Bus are all mental pits for me. I understand the basics, but details, no. Experts will be needed, fortunately I know a few.
The chassis will be relatively easy to design and build, though I will most likely sub out the final product after I get the geometry where it needs to be. I can make steel stick together, but many can do it so much better than I can.
The motor gear reduction units will be fully custom. The steering will be highly modified. If I stay with 64" width I can use standard suspension arms, if I go 72" (which is the plan), all of those will be fully custom. The Cross Link shocks will be heavily modified.
I will be soliciting sponsorships for it. This is a technology development platform, not only as the initial build, but ongoing development over the next several years. As sponsors come on board, I will post up. If you are interested in sponsoring electric vehicles in general, post up! I am sure there are a lot of teams who can use some help with both $, expertise and product.
Racing is not the path of least resistance. (oooooh)
We do it 'til it Hertz! (Booooo!)
If you see a Sine, Wave, or follow the arrow, your choice. (Staaahhhop!)
Please keep questions Current. (Sob...stop...)
Thank you, I'll be here all week.
Who is building electric and what are your challenges?
