Electric power steering
Csmart
Looking at installing electric power steering on our 1985 raceco 1600
Anyone out there with info on units and reliability in race mode? Current manual steering
Any help would be great
JWHracing
44
42
I sourced most of the parts myself, except for the wiring harness/control module. I bought mine from epowersteering.com
If you want to save a few bucks, 2002-2007 Saturn Vue and 2005-06 Chevy Equinox units is what most use. Mine is from a 2003 Saturn. I bought an entire steering column from a junkyard for $150, plus the Basic controller from EPS for $85. I got the controller that comes with the potentiometer to adjust how much assist the unit gives. The shaft on the unit is a weird size, 16.5 mm so it takes special u-joints, not your standard 5/8 or 3/4 steering shaft size. epowersteering.com has the joints with the correct 16.5 mm size if you go that route.
I have had mine installed for over 2 years, with a Saco standard rack. I have had zero issues with it in both race and play modes. I'm running a full bodied, pan class 5 with 33" tires. Has not had an issue and once I converted it, I couldn't believe I hadn't done it sooner. The adjust-ability with the knob is awesome too as I occasionally drive my car on the street and don't need full assist, but can easily turn it up drive the car with one hand and not be fatigued at the end of a race.
Phillip Moores
74
21
I just installed the epowersteering.com unit on my car. I haven't had much seat time yet but so far it is awesome. Some people talk about a loss of feel but I do not find it to be an issue. You can save some $ if you are close enough to pick up the unit from the epowersteering.com guy in Ramona Ca.
RDC247
88
38
I've gone with the epowersteering route as well and about the only challenge I've had is figuring out which couplers and mounts I need....their website wasn't too informative. Because I couldn't make much sense out of their offerings, I called and was fortunate enough to talk to the guy at epowersteering about adapting the booster to my system and he said that you can cut the input shaft to length but you can't cut or modify the output shaft at all because its a torque sensing shaft (?) and cutting it will ruin it.
