Engine porn
Slippery P
Dec 8, 2007
2,849
3,344
Valley Center CA.
scottm
Feb 7, 2005
1,905
601
scottsdale AZ
www.cemaz.com
That's beautiful! Building engines is my favorite thing. I am building a new 7.4/454 for my '97 K3500 right now, and here is an exhaust port I did for it. Bargain porn!
scottm
Feb 7, 2005
1,905
601
scottsdale AZ
www.cemaz.com
AZ I meant my engine is bargain porn compared to those danzios!
green787
Jan 2, 2005
10,930
2,695
Southern, CA.
realsound.us
Using the "Flow Bench" at Palomar College in San Marcos, CA. what we discovered is that creating a rough surface traps the air molecules in little pits and eddys thus making the air flow over trapped air.... Air flows over air, better than a polished surface.... A polished surface has "cling"....
Also all that over sized hogging out of the intake manifold does nothing until larger valves are installed in the head..... larger intake and exhaust valves are the key..... Like 1.07 or larger intake valves... Of course the lift and duration of the cam affects it also.....
Jan 17, 2019
11,028
6,698
sandiego
' raise the intake, lower the exhaust' thats about all i know, however,polish the exhaust, especially 2 stroke, so carbon crap dont stick, is Mike Mendenhall still the porting guru?
Slippery P
Dec 8, 2007
2,849
3,344
Valley Center CA.
I guess I’m doing it all wrong 😑
Slippery P
Dec 8, 2007
2,849
3,344
Valley Center CA.
New class 1 engine for “Sheila” 900hp 8500 rpm, there was a lot of custom machine work in this build to make everything work just right.
green787
Jan 2, 2005
10,930
2,695
Southern, CA.
realsound.us
When you are all done, just sandblast the surfaces with course grit sand..... Test it on a flow bench if you don't believe me.... Air over Air is better than air over polished anything..... That's why the factories don't really care about the casting marks, and the sand cast roughness.... The limiting factor is valve size.....
green787
Jan 2, 2005
10,930
2,695
Southern, CA.
realsound.us
Has anyone here ever tested their BS designs on a flow bench.....??? Resist the urge to be science deniers.....
This is what I used at Palomar College back when we actually cared about cylinder head flow design.....
You "Shade Tree" mechanics may have never seen one.....
Seems to me that $1700.00 to actually know what you are doing is a very small investment......
Slippery P
Dec 8, 2007
2,849
3,344
Valley Center CA.
You mean like this one Green?
Yes we use a flow bench, and the intake manifold surface is not polished. They are finished with 60-80 grit depending on application.
scottm
Feb 7, 2005
1,905
601
scottsdale AZ
www.cemaz.com
I have 'some' knowledge here as well, though not nearly as much as green. Here is the stock 7.4L manifold on my heads just last week, verses a EFI Victor Jr. It's safe to say the victor flowed better, though I'm trying to see how well I can make it run and stay emissions legal.
scottm
Feb 7, 2005
1,905
601
scottsdale AZ
www.cemaz.com
Slippery, do you use spread bore blocks on your 600+ big blocks?
