Engine porn
Jan 17, 2019
15,064
9,559
sandiego
hmmm, efi pump, hook hose to lever/ ball valve, then hook up to a tube with a threaded end to accept mikuni jets, holly jets, what ever, in throttle body , simple butter fly style, sooo you push gas pedal valve opens, squirts e85& is in tune with butterfly position, badda bing( edit, wHaT CoUlD g0 Wr0nG?
Slippery P
Dec 8, 2007
3,342
4,547
Murrieta
Finally got a chance to finish the port work on these manifolds, off to cerakote they go. Oh and those boogers in the radius of the last pic did get removed. 😉
Slippery P
Dec 8, 2007
3,342
4,547
Murrieta
@Slippery P when the guides are cut down, do you find excessive valve rock? Maybe it's a non-issue due to frequency of rebuilding a race engine?
These are intake manifolds, what is cut down are the injector bungs.
Bricoop
Feb 6, 2006
5,937
3,485
San Leandro, CA
Slippery P
Dec 8, 2007
3,342
4,547
Murrieta
Very nice work. Can you share the tools/bits you use?
These helical burrs from Headgames motor works do all the heavy grinding / shaping, then they are finished with a 36 and 60 grit cart roll.
Those helical burrs are a game changer in efficiency and finish, they remove material like a MOFO but at the same time don’t dig a trench.
Bricoop
Feb 6, 2006
5,937
3,485
San Leandro, CA
View attachment 246476View attachment 246477
Cool. I have a couple spares around I want to play with. Their website recommends to not use on steel. What do you use on steel?
Slippery P
Dec 8, 2007
3,342
4,547
Murrieta
I don’t do very much porting on Iron, but if I do I have some ferrous metal burrs.
Slippery P
Dec 8, 2007
3,342
4,547
Murrieta
The scrap bin. I'm not sure there is any reason to port iron heads anymore. It's way easier to paint an aluminum head to look vintage than to port a vintage head.
The last iron head I ported was an AMC 401 head, the casting was soooo bad. I couldn’t put it together that way.
scottm
Feb 7, 2005
1,929
650
scottsdale AZ
www.cemaz.com
I like those helical burrs. Straight cut course-tooth burrs hog too fast on aluminum, too dangerous to use around gasket surfaces or seats. I usually use a fine tooth helical single-cut burr like normally used on steel, but spray a little teflon lube on the aluminum to prevent clogging. Slip, do you use electric grinders? I have two electric makitas. They spin too fast to use long shank burrs like your helical burrs, so I control speed with an old Variac variable transformer. Air tools are easier to use, but I don't want to torture my compressor.
