Engine porn
Jan 17, 2019
11,028
6,698
sandiego
here's some german porn, Vasek Polak 45 ' bat mobile', csl, ( sounded frikken evil), my strut brace fab😀👍
Slippery P
Dec 8, 2007
2,849
3,344
Valley Center CA.
Slippery P
Dec 8, 2007
2,849
3,344
Valley Center CA.
There is an injector in the runner being tested, but the other runners and various holes were not plugged. With the victor, I could feel air drawing in all over the place. But I was also surprised that it reduced flow through the head as much as it did, from 295 cfm bare to 267 with the victor on. Is that typical? I thought the victor might actually increase combined flow. Of course it's irrelevant, since an engine needs a manifold, and the victor was 40 cfm better than the stock one. Stock mani combined flow was only 220 cfm, and that's after a ton of work deburring, port matching, and line of sight blending. In fact I had to build up the outside with weld in places as I kept grinding through. I think the new 454 with the head and mani work, plus bigger injectors, cam, a 0411 corvette ecm and headers will make 400+ at the crank and hopefully 350 at the wheels, and pass az emissions. Do you have a chassis dyno too?
My experience has found better results flowing the manifold, head combo, when all the other runners are taped off at the flange. Don Losito told me that’s how it has to be done, and when Losito tells you something, you do it. 😂
Kinda opens a can of worms though because at that point why leave out the throttle body, right?
I usually take the numbers from the manifold head combo with a grain of salt, being that unless it’s an 8 stack individual runner manifold set up there are too many variables in how the air travels through a plenum style or single plane 4500 style manifold with out replicating the dynamics of a running engine, reverb, cylinder scavenging etc. It’s all good info, but in my opinion the head numbers are the most important. Yes we have a chassis dyno,
Jan 17, 2019
11,028
6,698
sandiego
i was told most important is each intake length is the same& same volume, i got that after i asked an engine dood why old can am era engines had different length& velocity stack dimensions, it was thought to spread out the tork band, but it hurt horsepower , oh well, its an ongoing r&d that costs lottsa cash👍(imagine going 240 mph in an ALUMINUM gas tank with a800-1200 hp engine bolted to the back with just a 1-1/2" thin wall 'roll hoop'...
Slippery P
Dec 8, 2007
2,849
3,344
Valley Center CA.
Correct, if you look at the inside of one of these big block manifolds, cylinder 3&6 have the shortest relatively straight runners, they are almost always the leanest cylinders in the engine by far. Not only that but the intake runners in the head aren’t all created equal, It’s 2&2 alike pairs. So individual cylinder trimming in the fuel mapping is critical.
green787
Jan 2, 2005
10,930
2,695
Southern, CA.
realsound.us
You can't touch a MacKay fuel injection system for under $5000.00....... Every McLaren builder wants that look under the rear window.....
scottm
Feb 7, 2005
1,905
601
scottsdale AZ
www.cemaz.com
Guessing an older 2 valve mc engine, like an XR200 or a yamaha TT?
Slippery P
Dec 8, 2007
2,849
3,344
Valley Center CA.
Feb 19, 2002
6,796
1,638
Easton, KS
TTR125. It was for a buddy, don't think I want to do that agian. Put the BBR cam in it. They do not offer springs for it as, "they don't need them". Well, both the motors he has have bent intakes soooooo. They do offer a new CDI box with a higher rev limit so I'm sure that helps...... Also took .020 off the head per their recommendation....... and there is no way to degree the cam......
michael.gonzalez
Mar 13, 2018
4,863
1,827
Camarillo, CA
www.facebook.com
McMaster some baller springs. Dual spring it while you're at it! Lol.
I know YFZ450's did a 'YZF mod' where they put one of the cams fwd or reverse one cam gear cog.
Does anybody have experience porting a 2-stroke? Just curious how differently that goes.
green787
Jan 2, 2005
10,930
2,695
Southern, CA.
realsound.us
With a 2 stroke it's about raising and lowering the ports to the maximum performance.... almost like a camshaft.... how long are the ports open.... too far and you loose HP.....
Feb 19, 2002
6,796
1,638
Easton, KS
There is a lot more to it than that, port shape/width are really dependent on ring ductility. Direction is also important to cylinder clearing without losing to much out the exhaust. Bigger ports need to be offset with reduced crankcase volume to keep the transfer velocities up. Then you get into squish band tuning and reed timing........
Jan 17, 2019
11,028
6,698
sandiego
power valve rate& timing, is important too, -de burr /edge chamfering ,take the sharp edges away on the ports, ESPECIALLY exhaust ports, ( ps ,long bed trucks are nice...
Total Loss
Jun 5, 2006
1,129
588
Prescott Valley, Az.
70s Can Am cars?
Just read Mark Donohues book. The Unfair Advantage...recommend it.
