It's got 3" Fabtech spindles, fox shox. The upper ball joint came out of the socket and I replaced both ball joints, the angle just doesn't look right, honestly I'm scared to drive the thing.
The angle doesn't look horrible but if a cheap Kragen or O'Reilly balljoint was used we wouldn't be surprised if you had the issue. Is the camber negative (top of tire lean in)?
Your not going to get a press in balljoint to stay....that deal looks like there is 0 droop travel and it's maxed out. Bring your preload down a little
