f150 gearing
segalsa
May 25, 2006
13
San Diego, Ca
Hey Guys, I need your input on something:
I have a 2005 f150 4WD that's running on 35s. The truck feels heavy and I am considering changing gearing from stock 3.73 to 4.56. My concern is that by doing that I will loose top speed as the engine will rev up too high and will cause problems with overheating, etc. Is there a way to reduce RPMs at the engine so when going at 75-80 mph it wont over rev ?
Thanks
SoDrty
Jan 15, 2006
25
Costa Mesa, Ca
first off, the truck IS heavy. 4.56 gears for 35's will get you as close to stock as you can get, but i would suggest getting a programmer so you can correct your speedo
and get rid of the top speed limiter. you'll get a little more power to turn those tires as well. As far as overheating, don't even sweat it, the newer F150 has one of the best cooling systems available.
