Jeepspeed1720
- 7
- 1
Curious if anyone else is running BFG KO2 35,s on their 2017 up F250 4x4. I bought the truck pre owned. Has a vibration that I’m pretty sure is rear driveshaft , but before I drop 800 bucks on a custom 2 piece shaft I thought I’d check to see if anyone has had the same experience. 2018 F 250 crew cab 4wd diesel. Only has 1 1/2” front levelers. No rear suspension mods. So driveshaft angle is still factory. Had the balance checked at two different shops. Second shop concurred wheels were true and balanced correctly. The new tires/wheels were installed the day after I purchased the truck. I’ve heard the one piece rear oem driveshaft is a pos. Rotating the tires doesn’t change anything. Thanks in advance
